Warehouse simulation software for better warehouse planning
Simulate receiving, put away, picking, and shipping. Compare warehouse layouts and automation levels with Visual Components before making changes.
Can your receiving area handle peak arrivals? Will pickers have to wait for replenishment? What happens at packing when order volumes rise? With Visual Components warehouse simulation software, you can model warehouse layouts and material flow, compare automation levels, and test options before making changes on the floor.
Talk to a simulation expert about the warehouse processes, demand, and automation options you want to compare.
What is warehouse simulation software?
Warehouse simulation software models a facility’s layout, resources, tasks, and material movement over time. It helps you compare how proposed operations perform under defined demand and timing assumptions. A 3D layout shows where storage and equipment fit; simulation shows how goods move from receiving to shipping.
Visual Components manufacturing simulation software supports warehouse and factory intralogistics planning. Warehouse simulation is a decision-support tool: it helps you identify the operational solution that best fits your goals, based on the data you provide and the scenarios you test. It supports planning rather than managing live warehouse orders or inventory.
Model the warehouse processes behind your decision
A change at receiving can affect put away. A faster picking process can leave packing struggling to keep up. Model the connected processes that matter to your project so you can see where a local improvement may move a bottleneck elsewhere.
| Warehouse process | What to test in the simulation |
| Receiving | Can the receiving area and available staff handle incoming goods, verification, and inspection without delaying put away? |
| Deconsolidation | Where might queues form when bulk shipments are split into smaller units for storage? |
| Putaway | How do storage locations, travel distances, and handling resources affect the time needed to move goods into storage? |
| Storage | How do storage capacity and aisle arrangements affect access, replenishment, and material flow? |
| Picking | Can pickers and material-handling resources meet order demand? Where do they wait for stock or transport? |
| Load consolidation | Is there enough staging space and handling capacity to combine orders into outbound loads? |
| Packing | Can packing and labeling stations keep up with picking output during peak periods? |
| Shipping | Can outbound staging and dispatch handle the planned shipment volumes and departure schedules? |
Include returns processing or quality-control steps when they affect capacity or flow. For example, test the inspection time and space needed before returned goods can go back into storage.
For inventory planning, use stock levels and replenishment assumptions to test their effect on storage capacity and picking availability. The model supports these decisions; a warehouse management system (WMS) monitors and controls live inventory.
Start with a warehouse planning question
Can a revised put away strategy reduce travel? Would another packing station help meet peak demand? Should you add a conveyor, use mobile robots, or keep forklift transport? Choose the question first so you know what to include in the model.
Start with the information you have:
- A floor plan or CAD layout showing receiving, storage, picking, packing, and shipping areas.
- Incoming shipment and order volumes, product mix, replenishment needs, and peak periods.
- Task frequencies, travel and processing times, equipment capacities, and shift patterns.
- Storage rules, staging-space limits, and routes for people, forklifts, and mobile robots.
When a travel time or demand estimate is uncertain, test a range. You’ll see whether a proposed layout or automation level still meets your goals when conditions change.
Use your drawings or CAD to build the warehouse layout. Add storage, workstations, conveyors, and material-handling resources where they matter to the decision. Then model what arrives, where it goes, and how long each process takes. Visual Components supports layout configuration and visual process-flow modeling, so you can connect the layout to the work it needs to handle.
Run the current or proposed operation as a baseline. Then compare alternatives: move packing closer to outbound staging, change the storage arrangement, or test conveyor transport against forklift or mobile-robot transport. You can also compare manual and automated steps to see how different automation levels affect the wider flow.
Keep order volumes, product mix, and shift patterns consistent when comparing these options. Review modeled throughput, waiting time, and resource utilization. Test peak demand as a separate scenario so you can distinguish the effect of higher volumes from the effect of a layout or equipment change.
Share the scenarios with warehouse operations, engineering, and your integrator. A shared 3D model makes it easier to review where goods queue, discuss trade-offs, and agree on what to test next.
Test mobile robots alongside warehouse traffic
An automated guided vehicle (AGV) or autonomous mobile robot (AMR) may move goods from receiving to storage, replenish picking locations, or carry orders to packing. Its capacity depends on more than travel speed. Loading times, task frequency, shared routes, and waiting at transfer points all affect the work it can complete.
Model those tasks alongside forklift and pedestrian movements where they affect flow. Can the proposed fleet keep up with replenishment demand? Do vehicles queue at a shared crossing? Would an extra vehicle help, or would a different route or transfer-point location do more?
Use the results to inform fleet-sizing and route decisions. Visual Components does not manage a live fleet, and modeled traffic is not a substitute for a site safety assessment. If you need to test actual controls against a virtual model, explore the separate virtual commissioning workflow. Confirm the controller and integration requirements for your project, including any WMS or fleet-manager connection.
See how customers use simulation
Vaisala: plan picking and repacking capacity
Before building its new logistics center, Vaisala modeled the facility to examine picking, repacking, material flow, and mobile-robot capacity. In the baseline simulation, repacking staff reached 98% utilization. Vaisala then split the workload across two shifts. The model helped the team assess staffing and flow before the facility was built.
MSK Finland: evaluate factory material transfers
MSK Finland modeled its factory intralogistics using floor plans, production data, and real material flows. The team tested transfer frequencies, routes, timing, and AGV behavior alongside human-operated forklifts. In one scenario, a stacker-type AGV reached 68% modeled utilization over an eight-hour shift. This factory example shows how teams can evaluate vehicle capacity against a defined set of material-handling tasks.
Plan your next warehouse change
Bring us a layout and the receiving, storage, picking, or shipping challenge you need to solve. We’ll help you decide what to model and which layout or automation options to compare.
Check the model’s assumptions against actual orders, travel times, equipment performance, and space constraints. Update it when demand or the layout changes. Use the findings to guide your plans, then confirm performance through installation testing and on-site checks.
Talk to a simulation expert · Explore manufacturing simulation
For broader sector context, explore intralogistics and warehousing. New to the planning process? Read smarter warehouse planning starts with simulation.
Frequently asked questions
Warehouse simulation software models a warehouse’s layout, resources, processes, and material flows over time. It allows you to test how goods move from receiving through storage, picking, packing, and shipping, helping you compare different layouts and operating scenarios before making physical changes.
You can test processes across the entire warehouse, including receiving, putaway, storage, picking, packing, and shipping. For example, you can identify where queues or bottlenecks may form, whether resources can handle peak demand, and how a change in one process affects other areas.
Yes. You can compare manual and automated processes, such as forklift, conveyor, AGV, and AMR transport. By keeping demand and other assumptions consistent, you can evaluate how different automation levels affect throughput, waiting times, resource utilization, and overall material flow.
Yes. You can model AGV and AMR tasks alongside forklifts and other warehouse traffic. This lets you explore questions such as whether a proposed fleet can meet replenishment demand, where vehicles might queue, and whether adding another vehicle or changing routes and transfer points would improve performance.
Simulation lets you build a baseline of the current or proposed warehouse and compare alternatives before implementing them. You might test a different storage arrangement, add another packing station, relocate work areas, or compare conveyor transport with mobile robots. This provides data to support layout, capacity, staffing, and automation decisions before committing to changes.
Introducing Arc OLP: From workpiece to robot program. Faster.
Arc OLP brings automatic weld detection, visual selection and editing, and automatic robot program generation into one focused workflow for arc welding. Prepare new jobs offline and use the same...
Beyond engineering: why 3D simulation is becoming a core business capability in manufacturing
Simulation is evolving beyond engineering. Explore how manufacturers use 3D simulation and virtual commissioning to improve sales, reduce risk, validate investments and optimize operations throughout the production lifecycle. Learn from...
Robot workcell design: test the layout before you build
Plan robot workcells in 3D. Compare layouts, check robot reach and motion, and test production flow before installation with Visual Components.
